Drilled Airbox
10 replies to this topic
#1 Dusky
Dusky
  • 5,322 posts
Posted 20 June 2016 - 09:22 AM
Here I am again ;)
To those who drilled their airbox before: where did you dril the hole(S), how many and how bad was the noise?
Im trying to figure out if 1 big hole would be better than multiple small ones, and where I should drill/dremel it to give the best performance without too much noise
Cheers!
#2 Fast Ivan
Fast Ivan
  • 2,910 posts
Posted 20 June 2016 - 09:30 AM
will it make much difference to performance?
#3 Dayo76
Dayo76
  • 23 posts
Posted 20 June 2016 - 10:13 AM
when i drilled my air box it made it quieter for some reason, i drilled holes around where theres a bit of an indent where the throttle cable is i think i put 5 or 6 13mm holes in it only because 13mm was the biggest the drill could take. i dont know if its the same air box but its off of a mk 3
#4 nicklouse
  • 18,711 posts
Posted 20 June 2016 - 11:04 AM
I would not bother. just make sure you are ducting cold are to the inlet.
#5 Dusky
Dusky
  • 5,322 posts
Posted 20 June 2016 - 11:45 AM
I think it would improve things a bit because the biggest limiting factor I have in the box is the big snorkle wich has an area ( at the entrance) of 1060mm² , where the elbow has an area of around 1900mm² and the 44mm carb throat is 1520mm² .
Another option might be to try to drill/enlarge the snorkle?
cheers
#6 tiger99
tiger99
  • 8,584 posts
Posted 20 June 2016 - 11:54 AM
Aerodynamics are not simple and intuitive, which is why drilling holes made one quieter and why drilling holes in the wrong place will reduce performance. You may be best to leave well alone, or prepare for a very long program of trial and error. Or maybe copy from one that has been proved to work on a rolling road on the exact same engine...
#7 1314cc
1314cc
  • 303 posts
  • Local Club: tumbleweedminisbristol
Posted 20 June 2016 - 12:42 PM
Check out www.calverst.com , look under technical info then air filtration. You'll see everything you need to know, according to his tests a drilled box with kn came out favourably
Edited by 1314cc, 20 June 2016 - 12:44 PM.
#8 nicklouse
  • 18,711 posts
Posted 20 June 2016 - 01:01 PM
http://www.calverst....air-filtration/
#9 blacktulip
blacktulip
  • 6,224 posts
Posted 20 June 2016 - 01:51 PM
4 holes 3/8" diameter at the front as you look at it then chamfer the edges to eliminate whistling
Edited by blacktulip, 20 June 2016 - 01:51 PM.
#10 monkey
monkey
  • 1,382 posts
  • Local Club: Diss Mini Club
Posted 20 June 2016 - 01:58 PM
Interesting reading!
#11 Dusky
Dusky
  • 5,322 posts
Posted 20 June 2016 - 07:43 PM
I've read that article a few times before, but he's not so clear on teh noise. :P
