Flushing Coolant And Bleeding System Guide? Mpi
2 replies to this topic
#1 electricfurnace
electricfurnace
  • 143 posts
Posted 21 June 2016 - 09:21 AM
Right, my overheating and blown expansion tank was the fan which had seized. I am fitting a new fan later today.
I am also fitting an Alloy new Minispares tank rather than the plastic standard ones.
Need to flush coolant system and refill and bleed. It's a 97 MPI.
Am I correct in this procedure:
1. Remove bottom rad hose.
2. Pull OUT lever on dash to open heater maxtrix.
3. Stick garden hose in header tank and run water through until it runs clear.
4. Stick bottom hose back on.
5. Refill via header tank with a 50/50 mix of water and antifreeze - do I REALLY need distilled or deionized water or is tap water fine?
6. Run car up to temperature until fan kicks in with rad cap off to bleed the system.
7. Wait for water level to drop slightly indicating air bled out and re top up.
Is that all correct? Cheers guys.
#2 Carlos W
Carlos W
  • 10,114 posts
Posted 21 June 2016 - 09:24 AM
Don't go daft with the garden hose, too much pressure may blow the heater matrix
#3 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 21 June 2016 - 09:49 AM
Take the heater pipe off and back flush it is best
