New to this, so sorry if I make mistakes!
I have restored a 1995 Mini Cooper to Mighty Mini spec. The car will start but will run rich and the idle will lower and raise from approx 850 to 1200 rpm then stall. Will keep running with me blipping the throttle. the spark plus will become very sooty.
All vacuum pipes new and checked. has been diagnostically checked with no faults on the code reader. All new sensors and Lambda sensor new. ECU checked and sealed for the race series. Tried two other ECU's. Its running no cat, as per MM spec. A trusted Mini race/tuning company has confirmed the lack of cat is fine.
I have noticed disconnecting the air temp sensor makes no difference. It has 5V at the connector and a continuity test with the sensor carefully over a candle sees continuity decrease with heat.
I started the restoration in 1999 and the car has been in dry storage since 2011. But I am at the same point still. I refuse to give up and want to understand the problem, And then maybe get racing! Any help would be much appreciated.
