Laygear Thrust Washer Shims....
2 replies to this topic
#1 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,840 posts
Posted 29 June 2016 - 05:44 PM
GUESSWORKS now has available a shim which is designed to be placed behind the larger of the laygear thrusts. This is to overcome the issue of oversized thrusts being difficult to obtain.
Designed for the A series and A+ 4 synchro gearboxes, shims are available in two sizes, 0.004" (0.10mm) and 0.008" (0.20mm) priced at £1+vat each. They are also available in a trade/multi pack where you gear 5 of each size ( 10 in total ) for £7+vat.
These are made in house.
http://www.guess-wor...argument=GW-LGT
#2 BaronVonchesto
BaronVonchesto
  • 531 posts
Posted 09 May 2019 - 05:27 PM
hmmm would those shims have the same problems as the old type thrust washers without the tabs?
#3 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,840 posts
Posted 09 May 2019 - 05:48 PM
Unlikely, they're captured between the laygear thrust and the case, neither of which move.
