A Cylinder Head On The A+ Engine, Can Be Possible?
Posted 01 July 2016 - 06:59 AM
Someone told that is not possible.
And another man told me that it is with some changes, but didn't specified.
Would you please help me on this.
Thank you
Posted 01 July 2016 - 07:24 AM
there is no real difference.
But there are many A and many A+ some may not work correctly as for instance a S 11 stud head on a 9 stub block would leak if the block was not drilled to suit.
big bore heads do not readily work on small bore engines without some block machining.
as you see it come down to specifics.
so yes the will fit. but some will need some form of work.
Posted 01 July 2016 - 07:50 AM
The later A+ didn't have a by-pass set up but that wouldn't prevent one from the other being used.
In fact the A+ engines up to about 1985 - 86 were fitted with the same heads as the A series.
Posted 01 July 2016 - 07:53 AM
Where does it leak? I've not had any loss in coolant or leaks AFAIK...
Posted 01 July 2016 - 07:54 AM
and then there is the MPI and SPI(?) that have the water temp somewhere else so no drilling in the head. and the MPI alternator mount on the head.
they will still work but solutions will need to be worked out.
but again it all come down to details.
Posted 01 July 2016 - 06:11 PM
An 11stud head on a 9 stud block will not leak. They're stud holes, whether the studs are present or not will make no difference.
To answer the original question, yes an earlier A series head can be fitted to a later A+ block.
Phil.
Posted 01 July 2016 - 08:24 PM
Posted 02 July 2016 - 07:22 PM
Posted 18 July 2016 - 03:31 PM
Posted 18 July 2016 - 04:24 PM
Depends which Cylinder head you are talking about .. any casting part numbers on the head you are thinking of fitting and to which engine?
Posted 18 July 2016 - 04:36 PM
Can anyone tell me what mods do I have to do at the Cylinder head (A) to fit on the A+ Block?
If like for like they just bolt on.
Posted 18 July 2016 - 08:19 PM
Many A+ didn't have a by-pass, so you may need to block that up (but IMO should as a matter of course).
Otherwise, as the other guys have already said, just fit it.
Posted 18 July 2016 - 08:34 PM
Posted 19 July 2016 - 08:54 AM
I'm looking for a 12g940
Edited by Milo07, 19 July 2016 - 08:55 AM.
Posted 19 July 2016 - 08:56 AM
