So I've stripped down my engine and seperated it from the gearbox so I can fit new seals gaskets etc and stop some oil leaks, It's gone from this, to this. I've etch primed it, then given it a couple of coats of zinc yellow.
Ok, so before I re-assemble it, the Haynes manual describes building the engine up then attaching it to the gearbox. Is this the best way or can I bolt up the stripped engine to the g/box casing, then bolt on the engine ancillaries?
