I'm a bit concerned with the hose coming around the wheel side of the Trailing Arm. I'd look at strapping it along the top of the Arm, for as far as I sensibly could, then bring it around the inboard side of the Arm, to the Slave, but check the clearance where it crosses around that it won't foul the Subframe or it could make for a bad day. To sensibly do this, it may require the removal of the original bracket, or slotting it and fitting a grommet to it and routing the hose through it.
I'd probably use something like these between the hose and the arm where I strap them
and likely use Stainless Steel Ties.
<EDIT: P Clips as the other guys have suggested would probably be better than stainless ties. >
Edited by Moke Spider, 02 July 2016 - 09:20 PM.
