Mpi Mini Won't Start
Posted 03 July 2016 - 08:02 PM
Posted 03 July 2016 - 08:05 PM
Starter moter failed?? replace it ...
Posted 03 July 2016 - 08:13 PM
Posted 03 July 2016 - 08:44 PM
Might be stating the obvious here but I'd check these :
1. Are your battery lead clamps both tight ...loose clamps would mean that only a jump would turn the starter but low amp items like fuel pump would still work.
2. Does the solenoid click on low amp (no jump)?
3. Do your instruments/ignition lights work when the starter doesn't?
We had a similar prob and it turned out to be a broken wire from the ignition switch.
Hope this helps
Posted 03 July 2016 - 08:51 PM
Posted 03 July 2016 - 09:06 PM
