Balancing!
5 replies to this topic
#1 Andy18
Andy18
    Just On Tickover
  • 5 posts
Posted 04 July 2016 - 05:41 PM
Hi all,
Am in the process of getting everything ready for my 1275 rebuild. I've got everything including a new verto clutch and flywheel so I can use a pre engaged starter motor. Just wondering how many of you would recommend getting this balanced. It's not a case of cost I'm just struggling to find anywhere in Staffordshire to do it and wondering whether it's essential. Any advice / recommendations appreciated.
Admin; apologies if this is in the wrong place. Andy
#2 carbon
carbon
  • 2,590 posts
Posted 04 July 2016 - 05:51 PM
Rebalancing should not be needed, a replacement flywheel should be already balanced.
#3 Dusky
Dusky
  • 5,322 posts
Posted 04 July 2016 - 05:53 PM
If you buy the pressure plate + flywheel assembly they should be prebalanced. If you only buy the flywheel you WILL need to get it balanced to the pressure plate.
#4 ACDodd
ACDodd
  • Mini Docs
  • 2,767 posts
Posted 04 July 2016 - 07:09 PM
This is my experience with recent clutches some are so far out its unbelievable.
Ac
#5 morley
morley
  • 903 posts
Posted 04 July 2016 - 07:10 PM
I'd get it balanced, the crank, clutch assembly and crank damper then you'll have a nice smooth running engine. While your at this stage of a rebuild it makes sense to do it all properly.
#6 skoughi
skoughi
  • 1,199 posts
  • Local Club: Shetland classic car club
Posted 04 July 2016 - 08:25 PM
After getting my clubman back on the road I feel that I should've spent money on a balanced verto clutch set up at the very least. I fitted the old set up with a new clutch plate and I would say there is a noticeable vibration, or maybe I'm still not used to driving an old Mini yet!
