Remove Torque On 1989 Rover Mayfair
engine
4 replies to this topic
#1 DeanLj12
DeanLj12
    Starting My Mini Up
  • 2 posts
Posted 05 July 2016 - 06:12 PM
Trying to replace the crank main seal on a 1989 rover mayfair, we have tried everything we can think of to get the torque off but it isn't working. Is there a trick or something we are missing?
#2 imaparana
imaparana
  • 580 posts
Posted 05 July 2016 - 06:26 PM
Get the torque off? What do you mean torque?
#3 robminibcy
robminibcy
  • 1,516 posts
Posted 05 July 2016 - 06:31 PM
tourque converter I think he means. Presumably you've got a flywheel puller on it but its stuck? If so get the puller as tight as you can then try some penetrating fluid around where it joins the crank. Often left for some time with a puller tight they will shift.
Edited by robminibcy, 05 July 2016 - 06:32 PM.
#4 DeanLj12
DeanLj12
    Starting My Mini Up
  • 2 posts
Torque converter, sorry my wife was typing for me.
#5 limby2000
limby2000
  • 366 posts
Posted 06 July 2016 - 08:36 PM
You won't get it off without the puller, its also a different puller to that on the manual unless you have a universal puller. Also don't undo all six bolts on the t/c only every other bolt to fit the puller to, otherwise you may develop a leak.
