Paper Oil Filter Housing Leak
5 replies to this topic
#1 mk=john
mk=john
  • 1,167 posts
  • Local Club: Milton Keynes Mini Club, Mini Cooper Register
Posted 04 September 2006 - 07:14 PM
Hi All
I have a 998cc Mk1 Cooper which has the paper filter type oil housing. After a long run yesterday, I found when I parked the car outside my garage, oil was dripping from the centre of the housing where the bolt is located.
It is dripping quite a lot with the engine running, about 6" diameter patch is left after about 5 minutes of running.
Can anyone please tell me where I can obtain a sealing kit for the centre bolt, for this type of filter housing?
#2 m1n1
m1n1
  • 764 posts
  • Local Club: I'm unsociable
Posted 04 September 2006 - 09:03 PM
You normally get them when you buy a new oil filter. It would be more convenient for you to buy a new one then you can just replace the lot in one go. Any good motor factors should have one, but be sure to check the box for them!
#3 mk=john
mk=john
  • 1,167 posts
Posted 04 September 2006 - 09:38 PM
Hi
But I am not using a modern type spin on filter. I understand that is the case, but I want to find the sealing kit/ring that is used for the retaining bolt for the old type paper filter housing.
#4 m1n1
m1n1
  • 764 posts
Posted 05 September 2006 - 10:23 AM
i was refering to the paper oil filter! i have bought a fair few in the past. :D
#5 Big_Adam
Big_Adam
  • 7,435 posts
Posted 05 September 2006 - 02:53 PM
i was checking mini spare and they all come as a bear filter.
i'll have a search for some seals tho.
think this could be it
http://www.minispare....aspx?pid=36420
Edited by Big_Adam, 05 September 2006 - 03:00 PM.
#6 Garagiste
Garagiste
  • 336 posts
Posted 05 September 2006 - 04:10 PM
Pretty sure mine came with the seals, and they even stock them at Halfrauds.
And yes, defo the paper type as they were fitted to all the autos.
