Removing The Servo
10 replies to this topic
#1 Mini-mad-jack
Mini-mad-jack
  • 18 posts
Posted 10 July 2016 - 09:32 PM
Hi guys I'm just wondering that I would need to convert from my brakes which have a servo to not running one? I have aloy 4 pots on the front and standard back brakes if that helps. I'm also thinking of fitting a an adjustable brake bias valve but is it worth it the car will be used for track and weekend driving? Many thanks
#2 Dusky
Dusky
  • 5,322 posts
Posted 10 July 2016 - 09:52 PM
New MC and pipe converting kit.
Adjudtable brake bias valve has lovers and haters.
#3 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 11 July 2016 - 11:08 AM
Mini rear brakes dont do much and increasing the bias to the rears is going to make the rears more prone to lock up under heavy braking, as for removing the servo it will increase your input at the pedal.
#4 Northernpower
Northernpower
    Mr. 7-Port
  • 2,412 posts
  • Name: Graham
Posted 11 July 2016 - 11:12 AM
If your car was built with the servo you must inform the insurance company. They don't always take too kindly to changing the spec on the brakes and they like it even less if you've done any other modifications to increase the power output of the engine. I wanted to remove mine and the premium increase was significant.
#5 tiger99
tiger99
  • 8,584 posts
Posted 11 July 2016 - 03:46 PM
The adjustable balance valve, or any other method of achieving the same thing, is illegal on the road.
#6 Dusky
Dusky
  • 5,322 posts
Posted 11 July 2016 - 04:02 PM
*within reach of the driver.
#7 James_eaton_thewholething
  • 1,063 posts
Posted 11 July 2016 - 05:09 PM
And only fails IVA test not MOT. In fact only way it would fail on the mot would be if it leaked
#8 Icey
Icey
  • 1,554 posts
Posted 11 July 2016 - 08:48 PM
If the servo is one that acts on a pivot (directly connected to the pedal rather than the remote type) you'll also need to change the brake pedal itself as the angles are different (the pedal will sit high) and the return springs are different across the clutch and brakes pedals.
The bias valve is also unnecessary, you just need to use the right size rear pistons - there is a good website with all the information on somewhere, I can't find it at the moment. An example is if you use a yellow-tag with the standard rear pistons as fitted with 8.4" servo assisted front brakes you'll lock the rear wheels very easily, you'd need to use a 1/2" bore rear pistons to re-balance the brake effort.
Edited by Icey, 11 July 2016 - 09:09 PM.
#9 Mini-mad-jack
Mini-mad-jack
  • 18 posts
Posted 11 July 2016 - 09:43 PM
Okay this seems a lot more complicated then I originally thought I will do more research into this. And on the side of insurance mods the whole car is going to be modified in some way or another so I'm sure the servo won't make much of a difference lol
#10 timmy850
timmy850
  • 3,397 posts
  • Local Club: MITG
Posted 13 July 2016 - 07:37 AM
This is the list of original spec brake components (about halfway down the page):
http://www.minispare...rt.aspx?1~9~105
#11 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
  • Local Club: Loan wolf
Posted 14 July 2016 - 09:16 PM
You'll need one of these http://www.ebay.co.u...ZPl-ibovOF8JtMw a pedal box and a bit in piping.
