Leak Down Test
3 replies to this topic
#1 Joe555
Joe555
  • 240 posts
Posted 13 July 2016 - 10:52 AM
When I am testing No 2 at TDC on compression I get air coming out of No 4 plug hole. Any ideas ?
#2 ukcooper
ukcooper
  • 1,625 posts
Posted 13 July 2016 - 11:00 AM
Hole in the piston / valve dropped or seal ??
#3 ACDodd
ACDodd
  • Mini Docs
  • 2,767 posts
Posted 13 July 2016 - 11:31 AM
Leaking inlet valve.
Ac
Edited by ACDodd, 13 July 2016 - 11:31 AM.
#4 Joe555
Joe555
  • 240 posts
Posted 15 July 2016 - 04:50 PM
I have lapped the valves in and put the head back on without the push rods and manifolds. Rechecked and no air coming between no 2 & no 4 but I can hear air coming from No 3 inlet & exhaust ports, so I will lap those valves again. So it looks like the No 2 & No 4 was a valve problem. However on no’s 1, 2 & 4 cylinders I can hear air coming from the push rod holes.
 The reason that I started looking in the first place is because I had lost water from the radiator and it looks like it is coming from a stud hole. Photo attached.
  • Attached File  012.JPG   95.84K   13 downloads
