Timing Chain Cover Stiffner Plate?
12 replies to this topic
#1 speedwell1
speedwell1
  • 107 posts
  • Local Club: m4 minis
Posted 13 July 2016 - 08:09 PM
Ive just a guy on ebay in the usa selling a stiffner plate for timing covers, looks like it bolts to the bottom of the outside of the timing civer using the original bolt holes and stiffens the cover up to stop leaks? Anyone used one at all? Did it stop the leak ?
#2 speedwell1
speedwell1
  • 107 posts
Posted 13 July 2016 - 08:13 PM
Look at this on eBay http://www.ebay.co.u...m/131870380290. Heres the link
#3 Northernpower
Northernpower
    Mr. 7-Port
  • 2,414 posts
  • Name: Graham
Posted 13 July 2016 - 08:16 PM
The link doesn't work for me.
#4 speedwell1
speedwell1
  • 107 posts
Posted 13 July 2016 - 08:23 PM
Maybe its because I did it off my phone, not sure sorry
#5 nicklouse
  • 18,999 posts
Posted 13 July 2016 - 08:47 PM
Listing not available or removed.
Interested in how it works as there is not a fat surface to clamp to.
#6 Carlos W
Carlos W
  • 10,115 posts
Posted 13 July 2016 - 08:53 PM
http://www.ebay.com/...d8AAOSwOVpXfk2X
Are they that flimsy?
#7 Spider
  • 15,685 posts
Posted 13 July 2016 - 09:08 PM
Can't say it's somewhere I've ever had a problem with leaks from. 99.99999% of the time, Oil Leaks from the timing cover are from the seal, because either the Harmonic Damper has a groove worn in it and / or the cover hasn't been centralised.
But, not from the gasket because the cover needs some additional clamping.
#8 nicklouse
  • 18,999 posts
Posted 13 July 2016 - 09:33 PM
Can only see that as making problems. As it will squash the ribs distorting the cover and ripping the gasket.
#9 Northernpower
Northernpower
    Mr. 7-Port
  • 2,414 posts
  • Name: Graham
Posted 14 July 2016 - 07:58 AM
It looks like someone has invented a solution to a problem that doesn't exist.
#10 ace01
ace01
  • 458 posts
Posted 14 July 2016 - 10:08 AM
Early minis had two shaped plates that went into the groove of the timing cover and used the bolt holes to secure them.  It was deleted sometime around 63/64 I think, so obviously deemed unnecessary.
#11 speedwell1
speedwell1
  • 107 posts
Posted 14 July 2016 - 10:03 PM
My cover definitely leaks from around the bottom as described, and despite renewing the gasket on numerous occassions it always leaks, ive ordered one, once ive fitted it ill report back
#12 GraemeC
GraemeC
  • 7,467 posts
Posted 15 July 2016 - 06:23 AM
A new, undistorted cover fitted correctly would probably solve your problem.
This looks like a recipe for over tightened bolts and stripped threads in the backplate.
#13 tiger99
tiger99
  • 8,584 posts
Posted 15 July 2016 - 12:34 PM
Ace01, my MK 1 van had these little curved plates but my later Minis did not. I think they would have been on early Moggy, A35 and A40 etc too.
But my later Minis never had them, as you say. None of them leaked at the timing cover gasket, only the oil seal, and then only at high mileage.
