Driveshaft
4 replies to this topic
#1 paul b
paul b
  • 26 posts
Posted 14 July 2016 - 06:08 AM
Hi there, another problem found :ohno: , After putting front sub frame back together, i have found that when the car is lifted with the jack the passenger side driveshaft is looking ok with a gap between the sub frame and shaft, The driver side on the other hand is actually resting on the sub frame so when we turn the wheel it catches the full revolution, any ideas please,
#2 timmy850
timmy850
  • 3,560 posts
  • Local Club: MITG
Posted 14 July 2016 - 06:33 AM
Your rebound rubber might be worn out or missing? It should prevent the wheel dropping too low
http://www.minispare...ion/2A4267.aspx
#3 Dusky
Dusky
  • 5,322 posts
Posted 14 July 2016 - 07:55 AM
Does it catch while driving?
#4 paul b
paul b
  • 26 posts
Posted 14 July 2016 - 10:43 AM
Have not had the car on the road as yet, when its off the jack it looks fine,Think i will change the rebound rubbers first see how we go cheers,
#5 tiger99
tiger99
  • 8,584 posts
Posted 15 July 2016 - 09:44 PM
Are the engine mounts in good condition? A sagging engine can cause the problem, if the rebound rubber is ok.
