Help - Warning Lights Flash Indicators Don't
electrical
4 replies to this topic
#1 ryomini
ryomini
  • 583 posts
Posted 14 July 2016 - 01:40 PM
Hey
it feels good to be here
on the forum and where I have finally got to in the rebuild of a 1993 SPI
I am going through some diagnostics, the cooling system, brakes, clutch and so on
I just got a battery in the boot and was amazed to see that everything seems to work - I am such a spanner with electrics
when I put the hazard / warning lights on all 4 indicators flash in a regular pattern but when I use the indicator stalk nothing happens
can someone point me in the right direction as to what I should check or should look for
to get the indicators to work normally
thanks
#2 Wiggywithahailo
Wiggywithahailo
  • 505 posts
Posted 14 July 2016 - 01:52 PM
Check the fuse box they tend to corrode from behind plus the fuses Also the connections in the loom but could probably be the stalk
I had the same problem and after lots of testing it was the stalk
Edited by Wiggywithahailo, 14 July 2016 - 01:57 PM.
#3 GusRox
GusRox
  • 163 posts
Posted 14 July 2016 - 02:55 PM
When I had this exact same problem, it was a dodgy Hazard light switch - even though the hazards seemed to work fine, it was stopping the indicators working.  I had everything apart, including the stalk, replaced the relay... and it turned out to be the blinkin' switch.
#4 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 14 July 2016 - 10:56 PM
Full circuit and colours is in the FAQs here http://www.theminifo...it-colours-mk4/
Check the circuit along its length will identify where the fault is, I assume your ok with a voltmeter?
#5 ryomini
ryomini
  • 583 posts
Posted 15 July 2016 - 01:34 PM
Thanks for all this good advice - it's all noted down on my fridge and I will get to it and
let you know what the culprit was
