Hey
it feels good to be here
on the forum and where I have finally got to in the rebuild of a 1993 SPI
I am going through some diagnostics, the cooling system, brakes, clutch and so on
I just got a battery in the boot and was amazed to see that everything seems to work - I am such a spanner with electrics
when I put the hazard / warning lights on all 4 indicators flash in a regular pattern but when I use the indicator stalk nothing happens
can someone point me in the right direction as to what I should check or should look for
to get the indicators to work normally
thanks
