90 1275 non cooper s . On the throttle the car runs great. Dip the clutch at a stop and car stalls. Barely even tries to idle. Checked idle mixture using color tune and no matter how much I turn mixture screw it will not show yellow only blue. Also air fuel ratio is 14-15 throughout rpm range but at idle goes off Guage at 18+ any ideas? Vacume leak or manifold leak?
1275 Will Not Idle
bigfish
, Jul 15 2016 12:49 AM
3 replies to this topic
Posted 15 July 2016 - 12:49 AM
Posted 15 July 2016 - 12:52 AM
A touch more info,.... it previously would idle but would drop 300 to 400 rpm then return to 900 idle. So I think it is safe to say same issue just got worse? Thanks
Posted 15 July 2016 - 04:40 PM
Suggest you check your crank endfloat in case the crank thrust washers are on their way out.
Do you get any unusual noises when you dip the clutch?
Posted 16 July 2016 - 01:43 AM
I think I found the problem. The vacume line to the brake booster had a Crack in it. Seems to be good now.
