Not Starting
18 replies to this topic
#1 pusb
pusb
  • 1,216 posts
Posted 15 July 2016 - 10:54 AM
Anyone that has seen my posts lately will see that I have just fitted a new engine, and I was having problems getting oil pressure and a spark at the plugs. I now seem to have solved those problems, but I still can't get the thing to start.
There is petrol coming through as the plugs are wet, and I think I set the timing right (initially about 8 degrees advance, but as it was starting I added a bit more advance to it).
What else could it be? The petrol in there is pretty old (about 9 months), but I did put some fuel preserver in the tank so shouldn't it be ok?
#2 nicklouse
  • 18,999 posts
Posted 15 July 2016 - 11:11 AM
so what was the timing? and what is it now?
you say about and you say some more......
so I am guessing you are talking static timing?
10 static sounds a lot. 5-6 is a good starting point.
standard engine?
petrol will be ok.
#3 pusb
pusb
  • 1,216 posts
Posted 15 July 2016 - 11:18 AM
standard engine?
petrol will be ok.
It was 8 degrees initially, an it wasn't starting, I then nudged the dizzy clockwise slightly.
#4 pusb
pusb
  • 1,216 posts
Posted 15 July 2016 - 11:19 AM
And yes thats static timing, standard 1275 a+ engine
#5 pusb
pusb
  • 1,216 posts
Posted 15 July 2016 - 01:21 PM
I've reset the static timing to 5 degrees, and I tried starting it. I could hear that it was almost trying to fire but wouldn't. The battery then went flat so I have had to put that on charge for now.
#6 nicklouse
  • 18,999 posts
Posted 15 July 2016 - 01:27 PM
ok while you are waiting for the battery to charge. pull the plugs and clean them and dry them out.
and oven is good.
may be leave the oven till the battery is charged and fitted so you can fit warm plugs to aid starting. when started set your dynamic timing.
#7 pusb
pusb
  • 1,216 posts
Posted 15 July 2016 - 01:31 PM
and oven is good.
Hotter spark plugs presumably make it easier to start then?
#8 nicklouse
  • 18,999 posts
Posted 15 July 2016 - 01:45 PM
one, you dry them out
two, it helps get the gasses burning.
is a good last resort to on a very cold morning. and put some sausages in at the same time for a breakfast.
#9 pusb
pusb
  • 1,216 posts
Posted 15 July 2016 - 04:41 PM
Well the oven trick helped slightly. When I tried again, the car would start for a second, and then die as soon as I let go of the key. I'm thinking my timing must still be out if it's doing that?
Unfortunately my battery went flat again so I didn't have a real chance to investigate it. I might let it charge up all night and try again in the morning.
#10 nicklouse
  • 18,999 posts
Posted 15 July 2016 - 04:50 PM
leave the battery on charge for at least 12 hours.
retard the timing a tad more are try again in the morning.
#11 pusb
pusb
  • 1,216 posts
Posted 15 July 2016 - 04:59 PM
Thanks, I will give that a try.
#12 pusb
pusb
  • 1,216 posts
Posted 15 July 2016 - 05:00 PM
Haynes is useless at explaining how to set up the timing on an electronic dizzy. It only really explains how to do it on a car with points.
#13 nicklouse
  • 18,999 posts
Posted 15 July 2016 - 05:46 PM
It is exactly the same really. It just comes down to working out how your set up triggers the coil.
The main thing is get the battery well charged.
#14 pusb
pusb
  • 1,216 posts
Posted 15 July 2016 - 06:26 PM
Yeah I'm starting to think now the battery is the main problem. It seems to completely drain after a few attempts to start.
#15 pusb
pusb
  • 1,216 posts
Posted 16 July 2016 - 09:23 AM
This is driving me mad now!
I have the timing set at 5 degrees, I have fuel and I have spark. So why won't it fire!?
I don't know what else I can do.
Anyone have any suggestions?
