Not Starting
18 replies to this topic
#16 pusb
pusb
  • 1,216 posts
Posted 16 July 2016 - 12:35 PM
Discovered the problem. No fuel coming through. Opened up the lid to the float chamber and it was bone dry inside. Topped it up and the car fired straight away. The manifold was smoking hot after just a few seconds of running so I've advanced the timing slightly.
So what will the most likely cause of no fuel coming through? Fuel pump?
#17 nicklouse
  • 18,998 posts
Posted 16 July 2016 - 01:00 PM
Could be. Connect another hose to the pump outlet to a container and crank the engine. Does it pump fuel?
If you have a helper just disconnect from the float camber and crank.
#18 pusb
pusb
  • 1,216 posts
Posted 16 July 2016 - 01:24 PM
No nothing pumping. Must be that then. Hope its not too difficult to change with the engine in situ?
#19 nicklouse
  • 18,998 posts
Posted 16 July 2016 - 01:58 PM
Not hard just make sure you read about the spacer down there. It is there for a reason.
