Can I Use A Manual Fuel Pump Whilst Keeping My Spi Tank Fitted ?
11 replies to this topic
#1 rhys-89
rhys-89
  • 1,549 posts
  • Local Club: minifreekz
Posted 19 July 2016 - 10:28 PM
I have an spi I'm converting to a twin choke webber. If I fit a manual fuel pump can I just leave the spi tank fitted or does it require power in order to allow fuel through ? I know if I keep the spi tank (powered) I will need to reduce the psi to the webber with an inline fuel regulator. I have one but wanted to keep the engine bay as clear as possible so ideally use the manual pump.
#2 nicklouse
  • 18,724 posts
Posted 19 July 2016 - 10:34 PM
The fuel pump in the SPi and MPI is in the tank. The Ecu controls it and the pressure provided.
You would need to remove the pump and adjust the pickup length etc....
Sell it and get an old tank.
#3 rhys-89
rhys-89
  • 1,549 posts
Posted 19 July 2016 - 10:39 PM
Without the pump energised will it still allow fuel through it if pulled through with a manual pump or does it total shut of unless energised.
#4 Fast Ivan
Fast Ivan
  • 2,910 posts
Posted 20 July 2016 - 07:55 AM
Without the pump energised will it still allow fuel through it if pulled through with a manual pump.
No
#5 Ethel
  • 26,107 posts
Posted 20 July 2016 - 08:30 AM
You could use a pressure regulator, like we do for turbos. Take it this isn't a road car?
#6 rhys-89
rhys-89
  • 1,549 posts
Posted 20 July 2016 - 08:54 AM
It will be a road car I think I'll swap out the tank may fit a fuel cell in the boot and a manual fuel pump. Would a manual pump be sufficient enough to supply a webber. Or fit a fuel cell with a facet pump ?
#7 Ethel
  • 26,107 posts
Posted 20 July 2016 - 09:12 AM
It's the engine's HP that dictates what max fuel flow is needed. You might benefit from a leccy pump to feed the Weber enough pressure.
I'd look in to emissions if it needs to pass an MoT.
#8 rhys-89
rhys-89
  • 1,549 posts
Posted 20 July 2016 - 09:25 AM
It's in a 91 model car so won't be needing emissions test. I think facet pump and fuel cell will be the way to go thanks for your comments.
#9 nicklouse
  • 18,724 posts
Posted 20 July 2016 - 09:35 AM
 most electric pumps need a regulator anyway.
#10 rhys-89
rhys-89
  • 1,549 posts
Posted 20 July 2016 - 10:06 AM
If I bought a fuel cell and facet pump and added my fuel regulator and mounted it all neatly in the boot would this be fine or does the regulator need to be at engine bay end?
#11 nicklouse
  • 18,724 posts
Posted 20 July 2016 - 10:44 AM
pointless fitting a regulator in the boot.
it should be mounted close to the carb.
#12 rhys-89
rhys-89
  • 1,549 posts
Posted 20 July 2016 - 11:16 AM
OK will look into a bit more thanks
