Timing Light Accuspark Sp8000
Posted 22 July 2016 - 04:10 PM
Hi I have just got an accuspsrk timing light sp8000.
Can anybody explain how it works and set it up on my mini.
Cristiano italy
Posted 22 July 2016 - 04:13 PM
Posted 22 July 2016 - 08:27 PM
Here's a pic
The 'R / A' button selects the Display between showing Engine Revs and 'Dialled In' Advance Angle (on the flash)
The '+ / -' key is to Increase or Reduce the Dialled in Angle
The '4 / 2' button is to select between 2 and 4 stroke.
(Sorry gazza, the Instruction linked were a bit lacking mate)
Edited by Moke Spider, 22 July 2016 - 08:30 PM.
Posted 22 July 2016 - 09:27 PM
This vid shows a guy using the analogue version on a V8 but you get the idea:
https://m.youtube.co...h?v=CorRd_pwZy4
Posted 22 July 2016 - 11:41 PM
Posted 23 July 2016 - 12:00 AM
But I just remembered the inductive pick up witch you attach to spark plug wire number one cylinder near radiator.
The arrow on it ;I set it pointing down and not up towards the spark plug.😨
Will this give me a wrong timing ?
Posted 23 July 2016 - 12:31 AM
And for the 6th time, don't exaggerate!
No, shouldn't matter.
So, with that new Timing Light, you'd disconnect the Vacuum Advance, set the engine to 1500 RPM (which you can see with the Tacho function), Set the Dial Back to 10 degrees and then line up the timing marks to TDC, check the RPMs and go back and forth a couple of times until it is right.
Then reconnect the vacuum line, set the idle speed and your done.
<EDIT: On reflection, your timing light is no good, so you'd better give it here
Edited by Moke Spider, 23 July 2016 - 12:32 AM.
Posted 23 July 2016 - 01:01 AM
Lol.
Thanks for the good advice .👍👍
So your sure the arrow on the pick up pointing away from spark plug gives no problems.
Posted 23 July 2016 - 03:08 AM
Ha ha ha .
Lol.
If it registers RPMs and Flashes, then no.
Posted 23 July 2016 - 03:42 AM
Molto grazie👍👍👍👍
Posted 23 July 2016 - 07:24 AM
Just woke up to ten new posts... About a timing light!
Today's going to be an exciting day 😜
Edited by Smackfiend, 23 July 2016 - 07:24 AM.
Posted 23 July 2016 - 07:52 PM
Sorted the others
