Flywheel Locking Tab / Washer
2 replies to this topic
#1 matthewrussell
matthewrussell
  • 378 posts
Posted 23 July 2016 - 10:09 AM
Hi,
Quick question, I'm replacing everything to do with my clutch as I've had enough of it going....
My question is I've ordered a new Locking Washer Tab and bolt for the Flywheel, With the Locking Tab does it lock into the cranshaft cut out groves ??? or do you just put it on the bolt and tighten the bolt up ??? Stupid Question I know but just want to make sure!
For a Verto Clutch setup
Matt.
#2 MRA
MRA
  • 7,607 posts
Posted 24 July 2016 - 01:05 PM
If you have a Verto, then you will need the combined bolt /lock tab washer part.
Once you have the correct part it only fits one way and yes the raised section needs to be gently persuaded into the 2 slots, it doesn't need a lot just enough to stop it from rotating out.
#3 grayclassic
grayclassic
  • 23 posts
Posted 03 December 2016 - 11:08 AM
Thanks, I had the same question, but its difficult to see when changing the clutch i the car.
