Sc 5 Port Maps
9 replies to this topic
#1 Ann-Wilson
Ann-Wilson
  • 136 posts
  • Local Club: looking, (Live in Germany)
Posted 23 July 2016 - 08:52 PM
Hi folks, wondered if anyone can help me with a map..i have the specialist components 5 port kit. Base map will not run..very rich...plugs black.
I have the carb replacement model. My engine spec is 1293 newly rebuilt ( not run in yet), sw5 cam, stage 3 head..lightened fly, standard rockers, lcb into rc40 single box exhaust. Not looking for extreme power..just trying to get the car running so i can get it to sc.
Incidently they suggested getting it rolling roaded nearer to me...car is im poland...can anyone tell me if this is something that any rolling road tevhnocian could do...or do they need to know the software etc..how does one go about adjusting a map...without the rolling road etc....
Sorry for the questions...no experience in this area, thought the car would at least run with the base maps etc...and dont want to wreck my new engine just trying to get the car to sc...
Any help much appreciated...
Richard
#2 Allrounder
Allrounder
  • 188 posts
  • Local Club: Hereford Motor Club
Posted 24 July 2016 - 12:40 AM
If you want to map it yourself then you'll need a wide band lamda sensor, aem is the one I used and a friend to help as your driving along. When I did mine I also save all the variou maps so it's easier to see what changes you've made. You'll also need a timing gun to ensure the ignition/trigger wheel is set correctly.
Most modern r/r operators are fairly good at using various mapping software, again what I did was to talk to them first and even let them have the program to get familiar with before they saw the car.
Best of luck.
#3 Ann-Wilson
Ann-Wilson
  • 136 posts
Posted 24 July 2016 - 05:47 AM
Thank allrounder,
This helps..i dont have the lamda sensor. Guess this is way forward...going to try other base maps from download section to see if any better. How do you find yours to drive?
When you say timing gun..do you mean strobe?
#4 Allrounder
Allrounder
  • 188 posts
Posted 24 July 2016 - 08:13 AM
Yes a timing strobe. Had my kit for over 4 years now and wouldn't go back to a carb/distributor set up. Similar spec to yours but with 1310cc. It drives so well, no flat spots and instand throttle response plus good torque and 40+ mpg. Once yours is set up you'll be really pleased I'm sure.
#5 Ann-Wilson
Ann-Wilson
  • 136 posts
Posted 24 July 2016 - 06:04 PM
the fact that the spec is similar...? does that mean that your map might help mine run? or is this dangerous to try?
#6 limby2000
limby2000
  • 366 posts
Posted 24 July 2016 - 06:33 PM
Sc have wideband lambda sensors which are plug & play for 5 port 145 pound delivered, although ive been waiting for mine for 3 weeks now. There still waiting on their supplier.
#7 Allrounder
Allrounder
  • 188 posts
Posted 24 July 2016 - 10:59 PM
I could build a copy of my engine and my current map wouldn't be perfect. If you want to try it then I can sent you the file to look at or even try but that's up to you.
#8 Ann-Wilson
Ann-Wilson
  • 136 posts
Posted 25 July 2016 - 08:00 AM
Thanks would really appreciate it..just to look...where would one start? With the idle settings?
With regard to timing settings...what would i be looking for...compare timing on the guages from sxtune..with timing at flywheel?
#9 Ann-Wilson
Ann-Wilson
  • 136 posts
Posted 25 July 2016 - 08:03 AM
"If you want to try it then I can sent you the file to look at or even try but that's up to you."
Would you do this via email? Or via message in this forum?
#10 Allrounder
Allrounder
  • 188 posts
Posted 25 July 2016 - 09:30 AM
P/m me a email address. As for setting up, I'd wait till you got a lambda/or on a r/r so you can see the effect of the changes.
