Rear Quarter Panel Repair
3 replies to this topic
#1 Gijs
Gijs
  • 15 posts
Posted 24 July 2016 - 01:51 PM
I made a repair on my rear quarter panel. But what is the lip folded around at the underside? see Arrow at picture "back".
Thanks in advance,
#2 dyshipfakta
dyshipfakta
  • 1,696 posts
Posted 24 July 2016 - 02:25 PM
It's not folded around there are 2 pieces that meet I presume they are spot welded together from factory then you have a u shaped piece over the top like the seam strips.
#3 tiger99
tiger99
  • 8,584 posts
Posted 24 July 2016 - 05:17 PM
Correct, with a couple of spot welds, plug welds are ok too. The cover strip is a legal requirement (no sharp edges). I remember advising someone a few years ago to make and fit one, which he promptly did, and made a good job of it too. It is easily done by folding a small piece of 0.9mm steel around something of about 2mm thickness in the vice. Or buy non-genuine part BMP129 from Somerford for £2.93. On principle I would make it myself and save the cash for things that are too complex to make at home.
Paint shell and finishing strip inside and out before fitting. I would suggest using an adhesive to fix it and keep water out.
#4 Gijs
Gijs
  • 15 posts
Posted 24 July 2016 - 06:44 PM
thanks guys, I will go the route of folding some strips, not to hard.
