Hi, I have taken one screw out of the plastic cover, is there another somewhere?
I need to get the steering lock / ignition off, is it easy?
Posted 24 July 2016 - 01:54 PM
Posted 24 July 2016 - 03:27 PM
What age is the car? If it's between 1976-1997 you'll have this steering column in which case there will be two screws at the top (one by the left stalk and the other by the key ignition barrel) and a hidden one at the bottom end of the steering column.
The bottom one is a little tricky to get at, the screw is on the top side of the steering column (joining the two side's together), you should find the screw head is on the right hand side (ignition barrel side). If you're struggling to find it grab a mirror to help find it.
