Torque Wrench Question
5 replies to this topic
#1 Darwinism
Darwinism
  • 92 posts
Posted 25 July 2016 - 12:43 AM
Hi all,
What size torque wrench's do I need to cover all my '99 MPi's needs, 3/8, 3/4, 1/2, I can't afford all 3 right now so I need to know which is most important? Thanks.
#2 Darwinism
Darwinism
  • 92 posts
Posted 25 July 2016 - 02:33 AM
Not to worry, after digging up some old post I figure a 3/8 8-60 should do what I need for the time being.
#3 Anthony30
Anthony30
  • 1,467 posts
  • Local Club: N/A
Posted 25 July 2016 - 06:05 AM
1/2'' torque wrench would be ideal. :highfive:
Edited by Anthony30, 25 July 2016 - 06:22 AM.
#4 nicklouse
  • 18,711 posts
Posted 25 July 2016 - 07:19 AM
size depends on what sockets you have.
what range depends on what work you plane on doing.
I don't advise using a torque wrench at the limits of its gauge.
#5 Spider
  • 15,176 posts
Posted 25 July 2016 - 08:08 AM
The most reached for Torque Wrench I have is a Warren & Brown 3/8" Drive. It goes from 10 to 75 ft/lbs, so for engine building and many other tasks that range well covers it.
One thing I do prefer with this one over any 1/2 Drive one is it's lighter and so it gives a much better feel.
#6 Darwinism
Darwinism
  • 92 posts
Posted 25 July 2016 - 09:20 AM
Thanks for your replies, I have a better range of 3/8 sockets, the one I'm looking at has a range from 8-60Nm so should cover most my needs after looking through the rover manual, the only things it can't cope with are the following.
Timing gear nuts 90 Nm
Crankshaft pulley bolt 150 Nm
Flywheel to crankshaft - bolt 150 Nm
Flywheel centre bolt 150 Nm
First motion shaft gear nut 200 Nm
Front hub to drive shaft - nut 260 Nm
How much room would you give on either end?
Edited by Darwinism, 25 July 2016 - 09:21 AM.
