Dash Pot Gasket
Best Answer bigfish , 26 July 2016 - 11:22 PM
I purchased the car a year ago. Said to have rebuilt 1275 non s , rebuilt carb ect,... Basicly a shell and a massive amount of boxes of new parts. Fast forward 8 mths, car is now running but has terrible idle. I changed carb to intake gaskets , changed all vacume hoses, slightly better but no joy. I removed the carb, rebuilt it , and stoned the flange and put it back on car. I noticed in rebuild kit it was ,what I thought, missing the seal for dash pot. Which led me to this question . The best I can figure is said rebuilder of the carb to first time had no clue. I think the rubber seal used on the dash pot when I removed it was actually the float end cap seal.
I have removed this seal and would you believe the car has a great idle and runs like a new one. Thank you to all on this site that offered help. Just to check everything vacume wise I sprayed starter fluid all around the carb and no rpm increase. Lesson learned just because it has it when you dismantle an item, it is good to check it is suposed to have it! Go to the full post
13 replies to this topic
#1 bigfish
bigfish
  • 33 posts
Posted 25 July 2016 - 11:59 PM
Can anyone tell me if there is suposed to be a gasket between the dash pot and carburetor body?
Thank you in advance
#2 Spider
  • 15,201 posts
Posted 26 July 2016 - 03:44 AM
No, there's no gasket.
#3 fenghuang
fenghuang
  • 796 posts
Posted 26 July 2016 - 06:58 AM
Like Spider says ... No.
Presumably you've got a HIF or an HS?
#4 bigfish
bigfish
  • 33 posts
Posted 26 July 2016 - 01:49 PM
Thanks for the help guys. I have a hif 44 on a 1275. I will head out and remove the gasket.
#5 nicklouse
  • 18,732 posts
Posted 26 July 2016 - 02:16 PM
 err you cant remove it as there was never one made to remove.
http://sucarb.co.uk/...ter-dismantling
Edited by nicklouse, 26 July 2016 - 02:17 PM.
#6 fenghuang
fenghuang
  • 796 posts
Posted 26 July 2016 - 02:18 PM
Before you do ....!
It might be worth posting a picture with an arrow pointing to where the gasket is.
If there's one already there (and it's not o E you've put I yourself) there may be a reason for it, or zone confusion about where it is.
to be honest if we've understood your question correctly, I'm surprised there's a gasket that fits.
#7 Dusky
Dusky
  • 5,322 posts
He couldve made one out of gasket paper.
#8 bigfish
bigfish
  • 33 posts
Posted 26 July 2016 - 11:22 PM   Best Answer
#9 Mini ManannĂ¡n
Mini ManannĂ¡n
  • 2,860 posts
  • Local Club: man Estate
Posted 27 July 2016 - 01:13 AM
A happy ending!  :wub:
#10 Spider
  • 15,201 posts
Posted 27 July 2016 - 09:57 AM
It doesn't help when somethings been fiddled with previously then passed on that way!
Good result, nice work.
#11 fenghuang
fenghuang
  • 796 posts
Posted 28 July 2016 - 11:30 AM
Usually I count your comments as far better than most, but in this case, Spider, I'm shaking my head in despair at your utter naivety. It's a Mini Of course it's been fiddled with by a previous owner. ;-)
(No offense intended!!!!!!)
#12 tiger99
tiger99
  • 8,584 posts
Posted 30 July 2016 - 10:32 AM
The previous owner must have had ZERO understanding and IMMENSE patience to make such a gasket by hand. I wonder what imaginary problem he was trying to cure?
#13 fenghuang
fenghuang
  • 796 posts
Posted 30 July 2016 - 04:47 PM
Air getting mixed with the fuel?
#14 tiger99
tiger99
  • 8,584 posts
Posted 01 August 2016 - 11:59 AM
Yes, a very serious problem! 😅
