Water Pump
3 replies to this topic
#1 frenzy382
frenzy382
  • 79 posts
Posted 27 July 2016 - 10:16 AM
HI everyone,
can someone tell me what the symptoms are of a faulty water pump?
thnx.
#2 nicklouse
  • 18,998 posts
Posted 27 July 2016 - 10:20 AM
water leaks and over heating.
#3 tiger99
tiger99
  • 8,584 posts
Posted 30 July 2016 - 10:26 AM
Or maybe just a squeaking noise, which will sooner or later be followed by leaking. Try wobbling the fan to see if the bearings are badly worn.
#4 ryomini
ryomini
  • 583 posts
Posted 30 July 2016 - 10:28 AM
Usually
when the seal is gone water will leak through the small hole under the neck of the pump
this hole reveals that the SEAL is gone and that the pump must be changed
however it could leak from the gasket and may need to be reset with a new gasket and sealant
it could be leaking from a flared pipe or a cracked pipe, even a broken clamp
best is to run it while looking closely with a strong bright torch
a new pump and gasket is about 15 quid.  I have found permatex ultra black (which strangely enough is kind of grey)
is fine stuff and spread very thinly works well
