Cylinder Head Removed - What To Check
2 replies to this topic
#1 frenzy382
frenzy382
  • 79 posts
Posted 30 July 2016 - 03:36 PM
Hi everyone,
As part of possible head gasket failure, I'm off to remove the cylinder head shortly. I'm quite comfortable doing this, but obviously once it's all done, I want to ensure that I'm checking correctly.
Obviously I'll check the head gasket, and it will be replaced...however, whilst I'm in there...what else should I be doing/checking for?
Thnx.
#2 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 16,168 posts
  • Name: Neil
Posted 30 July 2016 - 06:55 PM
Use a decent straight edge to check the head face is true. Something like a steel rule.
While the head is off it may pay you to decoke the head so whip the valves out. Give it all a good clean up and then relap the valves. Do check the valve seats though for any damage.
If all good then fit new valve stem seals.
#3 carbon
carbon
  • 2,590 posts
Posted 30 July 2016 - 07:43 PM
If it's a 1275 head with the brass plugs, check that none of these are sitting low (not flush). In particular the plug between cylinders 2 and 3.
Check block area around head studs, may be worth removing studs and give stud holes slight countersink to make sure head sits right down on block.
