Hi Ya,
Trying to get the old girl back on the road. Been stood for 6 months
Thought i'd do a quick check before taking for mot of lights etc.
I was very disappointed!
So this is what works: (its short list)
Dipped beam ok but no dash lights, High beam (sealed beam headlamp ok, halgoen headlamp has nothing when stalk pulled on flasher,
Heater works, wiper motor works
Ignition lamp lights red.
Radio works
Heres what not working:
No rear lights at all, no number plate lights, tail lamps, dash lights, side lights, fog light, reversing light, hazards or indicators.
So basically not much!
I was so cross after spending all day doing other jobs, that i havnt begun to investigate this.
Does anyone have ideas what could be the cause?
If thing one of 3 things; fuse box corroded, inline fuses or connectors from front to rear loom.
Fuses did look ok, but not put a meter on them yet.
Need the car for the weekend so get to get it sorted asap.
Regarding the halogen main beam it take it is normal when go from dipped beam to main beam (if bulb faulty there should be nothing?)
Any help would be much appreciated.
