Toggle Switch For Rear Fog Light
9 replies to this topic
#1 Jakeywalker
Jakeywalker
  • 24 posts
Posted 02 August 2016 - 06:30 PM
Can anyone help me with identifying what all of the wires for the original rear fog light do? because I know theres 4 wires, and will be needing to only use 3 for a off/on (with led) toggle switch! :)
Edited by Jakeywalker, 02 August 2016 - 06:35 PM.
#2 Ethel
  • 26,104 posts
Posted 02 August 2016 - 09:32 PM
If you mean the original rocker, it has 2 wires for the switch and 2 for illumination. It must be wired to the headlights and have a telltale.
#3 Jakeywalker
Jakeywalker
  • 24 posts
Posted 03 August 2016 - 01:37 AM
so would these just be positive and ground for both the switch light and the fog light? I am wanting to use the original wiring with the new switch ideally! So surely one of the switch light wires provides the 12v and the other a ground, and the others on the connection provide the wiring to the fog lamp positive and ground? If these are being used with the 3 prong switch, would the 12v input come from the original switch light wire, the accessory be the fog light positive and then possibly both grounds from both the switch light and the fog light to be used on the negative connection together? Or would they need to be separately grounded?
#4 lrostoke
lrostoke
  • 6,923 posts
Posted 03 August 2016 - 04:43 AM
what are the wire colours ?
#5 Ethel
  • 26,104 posts
Posted 03 August 2016 - 06:28 AM
What switch do you have, 3 pins suggest crossover?
To be clearer, the rules say the fog must turn off with the headlights. The original does that by taking its power from the headlight supply - blue wire. The illuminated switches are run off the sidelights, the fog switch just has an extra coloured lens that's exposed when it's on. If you want a separate warning light just wire it in parallel to the fog light off the same switch pin.
#6 tiger99
tiger99
  • 8,584 posts
Posted 03 August 2016 - 08:56 AM
You are also now allowed to use the rear fog light(s) with front fogs, side and tails, and no headlights. However there are other complications and a legal configuration would need relays, diodes and probably a momentary action switch, as it needs to reset itself to off if the sidelights are switched off.
Just mentioning it for completeness.
#7 Jakeywalker
Jakeywalker
  • 24 posts
Posted 03 August 2016 - 11:03 AM
Just to mention, I am not thinking of changing the existing wiring configuration, just keeping it the same method as the standard rocker switch, but just wanting to implement it into an off/on 3 pin switch (with built in led)... Im sure there are loads of people who have already done it!
#8 johnR
johnR
  • 2,303 posts
Posted 03 August 2016 - 07:18 PM
Can't think what the third pin's for? I changed my rockers for toggles without leds - only two pins - power from headlamp in, out to warning light (and then earth)
JohnR
#9 dyshipfakta
dyshipfakta
  • 1,696 posts
Posted 03 August 2016 - 09:27 PM
JohnR
Rear fogs switch should be illuminated when they are on. Is part of MOT.
Edited by dyshipfakta, 03 August 2016 - 09:28 PM.
#10 Its a min
Its a min
  • 284 posts
Posted 03 August 2016 - 09:54 PM
Hi Jaywalker,
I changed mine a while ago to the illuminated toggle switch but from memory, the toggle switch has one pin for live, one earth and one auxiliary (fog light). If I remember rightly, the wiring to the rocker switch had either the earth or live piggy-backed (can't remember which ones o you will need to check the wiring) to the switch illumination as it's powered separately. The toggle switch is illuminated internally when it's switched on so you can eliminate the second (piggy-backed) wire. I hope this helps.
