simple question, should there be grommets in the 2 holes in the boot floor.
Grommets
Posted 03 August 2016 - 11:02 AM
Posted 03 August 2016 - 11:07 AM
I'd say yes
Posted 03 August 2016 - 11:09 AM
which holes?
Posted 03 August 2016 - 11:44 AM
Posted 03 August 2016 - 02:09 PM
The two holes in the spare wheel well should also have grommets.
Posted 04 August 2016 - 07:05 AM
What about the two holes in the bottom of the battery box?
Posted 04 August 2016 - 07:30 AM
The battery box is best left open.
Posted 04 August 2016 - 08:23 AM
But even with the grommet you would use some sealant to make it absolutely watertight, as I am sure you ddon't want a wet boot and corrosion problems.
You're never going to get a wet boot floor because you missed or didn't seal a grommet around the fuel line unless you've also fitted a snorkel.
I'd hazard a guess that 99% of the water present in Mini boots comes from the bootlid or light cluster seals.
Edited by Icey, 04 August 2016 - 08:24 AM.
Posted 04 August 2016 - 09:06 AM
I meant the two holes in the spare wheel well.
Posted 04 August 2016 - 09:16 AM
the two round holes should have blanking plugs.
http://www.minispare...classic/grommet boot floor.aspx|Back to search
Posted 04 August 2016 - 10:58 AM
ta ever so.
