Rear Valance Closing Plates And Rear Subframe Mount. Welding.
rust repair
8 replies to this topic
#1 Pepys
Pepys
  • 72 posts
  • Local Club: None
Posted 05 August 2016 - 07:22 AM
Has anyone welded in a set of these before without using a spotwelder? It is the part with all the closing panels and the rear subframe strengthening plate. Should I plug weld it, seam weld it or a bit of both?
How do you get a good contact between the plate and the bottom of the boot pan, as it is not easy to clamp there, self tappers?
Cheers everyone!
With big thanks to v21ash for the clean photo of the parts.
http://minispares.co...ic/ALA8623.aspx
#2 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 05 August 2016 - 07:33 AM
I would plug weld them in. Just drill lots of 6-8mm holes through the boot floor where the contact points are, use clamps or self tappers to pull the panels close together and then plug weld them all up. You can add some seam welds to the edge of the closing panels underneath too if you fancy it.
Ben
#3 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 16,076 posts
  • Name: Neil
Posted 05 August 2016 - 08:30 AM
Plug welding as Ben said. That's all I do with mine.
#4 alchall
alchall
  • Just Joined
  • 604 posts
Posted 05 August 2016 - 10:14 AM
As the guys have said, lots of plug welds, I did this recently, you can find the start of the process about half way down this page of my build thread if you want to have a look - http://www.theminifo...-sprite/page-15
#5 Cooperman
  • 23,324 posts
Posted 05 August 2016 - 11:26 AM
I recently plug welded mine in, but I turned the shell onto its side for better access and seam-welded around some of the edges.
#6 Daz1968
Daz1968
  • 2,058 posts
Posted 05 August 2016 - 04:11 PM
I have the m machine ones and they come in two pieces, but again I will be plug welding from underside when car is on the spit.
#7 Pepys
Pepys
  • 72 posts
  • Local Club: None
Posted 05 August 2016 - 08:09 PM
Cheers for that, everyone.  Puts my mind at rest. Does it matter if the plugwelds are through the boot or from beneath?
Nice project, alchall. It's like a ghost car... like you can see right through it.
#8 Daz1968
Daz1968
  • 2,058 posts
Posted 05 August 2016 - 08:45 PM
Don't think it matters, I do from underneath because car is on spit and upside down.
#9 sonikk4
sonikk4
  • 16,076 posts
  • Name: Neil
Posted 05 August 2016 - 09:49 PM
All the ones I have done have been on a spit. So from underneath means the boot floor looks unmolested.
Also tagged with one or more of these keywords: rust repair
