1985 mini mayfair 998cc, bought as an unfinished project so unsure if the fault was already present when last used 5+ years ago,
Issue - R/H indicators and tell tale on dash works fine
L/H indicators don't work, tell tale on dash stays solidly illuminated (doesn't flash)
Hazards don't work.
I have emery cleaned all contacts, joins and earths that I can find, and I have replaced the fuse box (old one was beyond repair) and all fuses, and also bulbs and relays.
I am beginning to think it may be a break in the loom somewhere so will be carrying out a continuity test.
Am I overlooking something else/obvious?
I've had a look through the search function and yet to find the answer, however there is a lot of results to go through so if anyone knows which one I should be looking at and can provide a link that would be appreciated too.
Thanks all
