Evening everyone,
Got a problem with my 1989 mini 30, 110000 miles, 998cc standard engine
It seems to be running on 3 cylinders and going very lumpy now and again. The spark plugs were changed a month ago, and the points gap has been set properly. coil and condenser were changed less than 6 months ago. rotor arm/distributor all in good condition
When the engine is running, pulling the HT lead off cylinders 2,3,4 (one at a time) - each one makes the engine drop rpm as it should. (cylinder 1 being closest to the radiator)
Pulling the HT lead off cylinder no. 1 when the engine is running there is no decrease in rpm.
Tried swapping the spark plug/changing the HT lead but no difference at all.
Car is loosing some water (which is a funny colour, unsure weather its oil or just a build up of rubbish)
Car is loosing some oil - no sign of any "mayo" in the rocker cover.
Car is also my daily.
had a 100 mile trip yesterday, 50 miles there 50 miles back, temp gauge was sitting just above half way on the flat, unless i went up a hill and it would increase to 3/4 up the scale, and downhill it would be normal.
Unsure what to do.
Any help is much appreciated
Angus
