No Spark From Coil
Posted 11 August 2016 - 09:15 PM
Installed new engine from Minisport 1293, stage 2 head. 1979, HIF44 carb, stage 1 exhaust.
Replaced all ancillaries as they were taken off old engine.
Established TDC, fitted distributor, connected all wires etc.
Engine cranks over fine but no spark from coil which is brand new and correct spec. Brand new battery also. HT leads also in good order.
I'm getting 12v+ at the + connection on coil, used test light with good earth and light is on when ignition turned on.
Placing the test lamp on both the + and the - terminals of the coil and the light briefly turns on but then goes out when ignition turned on, suggests a bad earth? But where?
It suggests there may be a short circuit somewhere but I have no idea where to check. I'm no electrics expert but have tried so many tests as per several forum posts and simply can't get to the problem.
Please help as I'm at the end of my tether!
Posted 11 August 2016 - 09:55 PM
with known good 12v at +ve on coil
all wires off the -ve coil connection - earth the -ve with a wire , break the connection - you should have spark - if not coil is suspect
is the dizzi points or electronic ? - if electronic - module could be faulty
things to check -
tacho wire removed - eliminate another possible fault - also remove any radio suppressor on coil
if points - clean them up / replace - change condenser - look at insulation washer & make sure nothing is shorting to base plate
check fine earth wire in the dizzi (points plate to outer body)
run a new wire on it's own to the coil -ve & points (to eliminate wiring fault)
report back with outcome
best of luck
Edited by sledgehammer, 11 August 2016 - 10:03 PM.
Posted 11 August 2016 - 10:23 PM
Posted 11 August 2016 - 10:35 PM
you can but better to connect a plug lead & plug rested on the head
less chance of a shock that way
Posted 11 August 2016 - 10:51 PM
Posted 11 August 2016 - 10:58 PM
it will or use a plug lead, if the coil then produces a spark then the coil is not being switched by the electronic module, are you sure thats wired up ok ? tests for the module if the wiring is ok is in the FAQs Electrical Section. Shout back if you need any more help
Edited by KernowCooper, 11 August 2016 - 11:01 PM.
Posted 12 August 2016 - 02:27 PM
How to test your coil:
Remove all wires from coil.
Measure the primary resistance (ohm-meter at + and - connectors)... Depending on what coil you have you should get something around 1 to 4 Ohms.
Measure the secondary resistance (ohm-meter at + OR - and at the HT-connector). There should be a couple of thousand Ohms, usually 5000-10000 Ohms... again, depending of type/brand.
I´ve had a new Lucas Sports Coil (the shiny golden one) that had infinite resistance on the secondary winding - broken from factory... Minispares has stopped selling them because of high error rates.
Edited by Magna-Flash, 12 August 2016 - 02:28 PM.
Posted 12 August 2016 - 09:24 PM
Not for a minute did I think I would have to check that on a brand new engine but a friend helped me tonight and that was what we discovered. Anyway have emailed Minisport and am awaiting there response!
Thanks again, much appreciated.
