Hi Moke Spider
Carried out the test as described but still no light.The brown/yellow wire does carry power with the plug in the alternator and the ignition on/engine not running.Took a look at the wiring and connectors everything seems ok but the printed circuited is giving me cause for concern,if you swap the bulbs and holder around it doesn't make any difference to the charging light although I have power to the circuit from the white and brown/yellow trace wires.Have cleaned the circuit around the bulb holder and can get a positive test across the circuit in this area,my test light operates but no charging bulb!
I had a charging light before swapping the alternator for a new unit which is rated at 70 amps,the car is a 92 Mayfair carb,bit lost on this one now might have to call a sparky in.By and by I noticed that there is a spade terminal on the back of the alternator that is live with the ignition on,unit type is A127 is this the norm also the the two brown wires off the back of the alternator plug are also live when disconnected ign on/eng not running.
