Hi all,
I've removed my heater unit on my 1988 Mini Mayfair as I had trouble getting to the clutch comfortably with my clown feet.
I've removed the heater pipes that go through the bulkhead into the cabin and have connected the hoses in the engine bay together and have left the heater valve in place in the closed position.
Is it best to leave it as it is currently set up with the valve closed. Or should I be running it with the heater valve open to allow the coolant to flow.
The way I see it is that at the moment there's no difference than running with the heater in place and the valve closed anyway but I just want to check.
If that is the case then I can use a blanking connector between the two hoses - I want to leave the hoses in place in case I ever want to put the heater back on.
Thanks,
Paul
