Hi everyone,
I'm about to install a stage 1 kit and am confident about installing everything except the new needle. Does anyone have any resources or guides I could follow? I took apart an old HS4 and learnt how to change the needle in that, is the HIF44 roughly the same? And lastly is there anything else I should be aware of when changing the needle? I bought in newly reconditioned from aseriesspares at the start of the year so it should be in good order
Cheers,
James
How To Replace The Needle In Hif44 Carb
The_Doctor
, Aug 15 2016 10:06 PM
3 replies to this topic
Posted 15 August 2016 - 10:06 PM
Posted 15 August 2016 - 10:16 PM
It s exactly the Same.
Only changing the Spring is slightly different. (Little circlip at the top of the piston wich you need to clip off)
Couldn't be easier. Remove the dashpot via the 3 screws holding it to the carb body. The needle is simply held in place by a retaining screw, remove this, pull old needle out, put in new needle and retighten screw. Make sure you fit the small spring to the base of the needle to.
Phil.
Phil.
Posted 15 August 2016 - 10:24 PM
Well that's fantastic to hear! Looking forward to it now :) Thanks so much for the replies!
