Mini Won't Accelerate To More Than 20Mph
9 replies to this topic
#1 ac427
ac427
  • 678 posts
Posted 17 August 2016 - 09:03 PM
My Mini has been sat around for years but i treated it to new oil, leads plugs, rotor arm and a distibutor cap and a decently charged battery.
The engine runs fine. There is oil in the HIF44 dash pot too. The points look fine and have been lightly emery papered to clean the contacts.
The engine will idle and rev right up the range to a good few thousand rpm.
All the wheel bearings are fine, the drums and discs turn freely and the tyre pressures are good.
I went for a little drive around the car park. It just would not accelerate to more than about 20 mph.  If i opened the throttle more it just started to die on me.
The only i can see wrong is an exhaust leak, where the LCB meets the exhaust system.
Could this be the cause of all the trouble?
#2 robminibcy
robminibcy
  • 1,516 posts
Posted 17 August 2016 - 11:58 PM
the lcb wont cause that no, has it got fresh petrol?
#3 ac427
ac427
  • 678 posts
Posted 18 August 2016 - 12:58 AM
yes, and a solid state pump.
could the clutch drive straps have anything to do with it?
i thought it might be consuming it's own exhaust gases and that was killing it?
#4 nicklouse
  • 18,585 posts
Posted 18 August 2016 - 08:12 AM
sounds like a sticking carb piston.
top off and give the insides a clean.
#5 Carlos W
Carlos W
  • 10,114 posts
Posted 18 August 2016 - 08:29 AM
Age of the car?
Manual or auto?
#6 ac427
ac427
  • 678 posts
Posted 18 August 2016 - 03:14 PM
The car is a manual, the engine is about 18 years old.
The piston in the dash pot moves freely.  Is normal 20W50 engine oil ok for the dash pot?
#7 ace01
ace01
  • 457 posts
Posted 18 August 2016 - 04:20 PM
Check the air filter.
#8 racingbob
racingbob
  • 3,061 posts
Posted 18 August 2016 - 07:51 PM
try 3.1 oil works well in mine or proper SU oil
#9 The_Doctor
The_Doctor
  • Just Joined
  • 62 posts
Posted 21 August 2016 - 11:59 AM
I've had something similar happen in a 1275 A series Allegro and what fixed it was replacing the sparkplugs. I had cleaned them so didn't think they would be the issue but decided to just in case and it sorted it right out. I'd give that a go if you haven't already.
Good luck!
#10 jt19
jt19
  • 745 posts
Posted 21 August 2016 - 12:04 PM
I take it you have the leads on the right way around?
