Metro 1275 Bhp Rating
Best Answer ACDodd , 22 August 2016 - 07:56 PM
It could be any where from 58 to 73bhp depending on the spec How well dialled in it is and condition. If well worn you'll be lucky to get past 60bhp. If its not tuned properly you'll be lucky to make more than 50!!
Ac Go to the full post
10 replies to this topic
#1 JamesC
JamesC
  • Just Joined
  • 125 posts
Posted 22 August 2016 - 04:01 PM
Hi guys
Can someone give me a rough BHP figure for a Metro 1275 engine with a Hif 44 carb and a sports exhaust?
James
#2 Carlos W
Carlos W
  • 10,114 posts
Posted 22 August 2016 - 04:14 PM
Standard head?
What exhaust?
Standard cam?
#3 gazza82
gazza82
  • 3,017 posts
  • Local Club: TMF+
Posted 22 August 2016 - 04:40 PM
63-72 .... https://en.wikipedia...ngine#1275_Plus
#4 adecooper
adecooper
    Starting My Mini Up
  • 4 posts
Posted 22 August 2016 - 04:57 PM
From memory early A series metro 1275 mid high 50's (?) A plus 63 ( the spi got to the same place by a different route!!) and the MG Metro was 72. Turbo was 90bhp though AR were allegedly a bit creative with their turbo test cars ( there was a lot of chatter at the time about Maestro Turbo press cars being  very non standard.)
The MG Metro engine was different in many regards to the standard 1275 and today would be a great start point for a non injected road mini?
#5 ACDodd
ACDodd
  • Mini Docs
  • 2,764 posts
Posted 22 August 2016 - 04:59 PM
Erm, not as easy as that many different specs and 4 cam types fitted. What one have you got?
Ac
#6 JamesC
JamesC
  • Just Joined
  • 125 posts
Posted 22 August 2016 - 06:25 PM
Hi guys
Thank you for the quick responses!
Unfortunately the engine tag has been removed and I am unaware of the engine year.
The inlet manifold has mini sport printed on to it, is it possible that it has a stage 1 kit?
The exhaust is a 2" diameter centre exit.
I believe the rest of the block is standard (head + cam)
The engine is an a+ if that helps.
James
Edited by JamesC, 22 August 2016 - 06:27 PM.
#7 ACDodd
ACDodd
  • Mini Docs
  • 2,764 posts
Posted 22 August 2016 - 07:56 PM   Best Answer
Ac
Edited by ACDodd, 22 August 2016 - 07:58 PM.
#8 Turbo Phil
Turbo Phil
  • 2,426 posts
Posted 22 August 2016 - 08:44 PM
With a 2" exhaust system on an almost standard 1275 you're probably making less power than it left the factory with regardless of condition.
Phil.
#9 JamesC
JamesC
  • Just Joined
  • 125 posts
Posted 22 August 2016 - 09:00 PM
Thanks to everyone that helped out!
#10 JamesC
JamesC
  • Just Joined
  • 125 posts
Posted 22 August 2016 - 09:02 PM
Phil.
Really? Well there are big plans instore for the future.
Edited by JamesC, 22 August 2016 - 09:03 PM.
#11 nicklouse
  • 18,655 posts
Posted 22 August 2016 - 09:06 PM
Phil.
Have to be really big like a turbo.
Also when you say 2" how are you measuring it? There is a correct way and a incorrect way.
