Mystery Knocking
19 replies to this topic
#1 New game mini
New game mini
  • 294 posts
Posted 26 August 2016 - 02:37 PM
Hi folks,
I know it's not ideal to ask about knocks and banging noises on here but I'm really at a loose end!!
My 86 998 is making a knocking/tapping sound which sounds like it's coming from the passenger footwell area. It's not a uniform tap, it kind of just goes along with the road surface.
It only does it when the car is moving (not an engine noise) but doesn't get worse going over speed bumps but that side will occasionally 'clunk' a bit over pot holes. There is no difference under braking and the car handles the same as usual.
The suspension cones and shocks have recently been replaced so are Good and everything is seated properly and the car is level.
We did try to take a video on my phone but my engine is quite loud so it didn't really work out 🙈.
I've looked everywhere (I can think) for something that could be knocking inside and out but now I'm stuck. Any thoughts much appreciated!
Thanks!
#2 Mini 360
Mini 360
  • 4,933 posts
  • Local Club: Independent
Posted 26 August 2016 - 02:52 PM
Lower engine mounts?
#3 Carlos W
Carlos W
  • 10,115 posts
Posted 26 August 2016 - 03:05 PM
Have you had the carpets up?
If could be a cracked floor or bottom subframe mount
#4 RedRuby
RedRuby
  • 1,201 posts
  • Local Club: No
Posted 26 August 2016 - 03:18 PM
Did you replace the knuckle joints when you did the suspensions? Rear front subframe mount, teardrop mount.
#5 sledgehammer
sledgehammer
  • 3,129 posts
Posted 26 August 2016 - 03:54 PM
toe board subframe mount ? or crack in that area
#6 Spider
  • 15,684 posts
Posted 26 August 2016 - 08:44 PM
Sounds very much like Steering Rack to me.
The Bush on the Passenger's side is likely worn.
#7 New game mini
New game mini
  • 294 posts
Posted 27 August 2016 - 08:31 AM
Thanks for the replies. I'll definitely check all of that thanks although I've not long had new engine mounts whilst having an engine swap and I had welding done on the subframe mount area as it was starting to corrode. I also had a new steering rack last November so I hope it's not any of that! I'll definitely check it all though, thanks. We didn't replace the knuckle joints as they seemed fairly new and the nylon cup wasn't worn (not best practice I know) could it be this?
Thanks again
#8 tiger99
tiger99
  • 8,584 posts
Posted 27 August 2016 - 10:55 PM
It is best to replace the knuckles every time the suspension is apart, because the cost of replacing top arms, if they get damaged when the nylon cups wear through, is about 50 times the cost of new knuckles.
But I concur with others that you should look for broken subframe to toeboard mounts. That will keep happening, so best to convert to a full set of solid mounts. Never mix solid and rubber, or you will do severe structural damage to the shell.
#9 sledgehammer
sledgehammer
  • 3,129 posts
Posted 28 August 2016 - 04:23 PM
+1 as above
& knuckles are cheap for what they do
a lot of load in that area
#10 New game mini
New game mini
  • 294 posts
Posted 29 October 2016 - 10:49 AM
Hi folks. I finally got round to having a good look at the subframe to toeboard mounts and they all seem fine. We've also been desperately trying to find anything that is rattling/knocking on the bulkhead but cant find anything so it looks like im going to have to attempt to replace the knuckles :X  :X . After doing the suspension cones we vowed NEVER (or at least for a while) to go near that area of the car again :ermm:. That'll teach me to do a job right the first time!
You can hear the offending rattle in this vid https://youtu.be/GmnLQNNS8E4
Edited by New game mini, 29 October 2016 - 04:11 PM.
#11 mikal
mikal
  • 240 posts
Posted 29 October 2016 - 12:37 PM
As Moke said, have you checked the steering rack U bolt/ nuts securing it to the front left of the car?
#12 cal844
cal844
  • 9,713 posts
  • Local Club: TFMOC
Posted 29 October 2016 - 04:33 PM
Steering rack end bush, or subframe mount related.....
#13 MrJenkinsEsq
MrJenkinsEsq
  • 38 posts
Posted 30 October 2016 - 11:00 AM
Sounds very similar to the mystery and infuriating knocking I had for a good couple of years. Went through everything checking subframe mounts, engine mounts, carb clearance against bulkhead, steering rack bolts, adding engine stabilisers etc.
Eventually replaced the steering rack itself and it was gone. Driving bliss from then on!
Edit. Doh, just seen that it's had a new steering rack!
Edited by MrJenkinsEsq, 30 October 2016 - 11:02 AM.
#14 New game mini
New game mini
  • 294 posts
Posted 30 October 2016 - 08:55 PM
Hey, thanks for the reply. Yea it had a new steering rack just under a year ago so hopefully that's fine. It's driving me crazy...I've got MOT in a few weeks so hopefully that'll pick up what it is if it's anything serious/dangerous. I'm gonna have 1 more go this week/weekend trying to find what it is and if I can't find it then sod it :P
#15 DEXISWOLF
DEXISWOLF
  • 545 posts
  • Local Club: Steel City Classics
Posted 30 October 2016 - 11:25 PM
Ive had it too for ages went through everything and was the rack , oh them damn steering racks xD
