Spi Gear Box 2Nd Gear Issue
Posted 27 August 2016 - 12:42 AM
The 2nd gear grinds when trying to go in at speed higher than 20km
Once in, it drives normal and stays in gear.
What could be wrong ??
Posted 27 August 2016 - 02:19 AM
baulk ring failure
Posted 27 August 2016 - 03:17 AM
As above, most likely the Baulk Ring is worn out. It's also likely the Synchro Hub Detent Springs have lost their 'zing' and also need replacing.
Sometimes the Syncho Cone on the gear itself can be worn or de-laminated as well. They are getting hard to come by for these gearboxes.
Posted 28 August 2016 - 03:27 PM
Posted 28 August 2016 - 07:44 PM
My experience of a later Mini MPi sounds similar but I had terrible grinding changing down from 3rd to 2nd. Sometimes 2nd would pop out. I managed it with careful gear changes but hardly spirited driving in a Mini.
I contacted John at Guessworks and he confirmed it was the weak baulk rings fitted to later Minis. Had the gearbox refurbished by him and now perfect. Top guy and first place to go regarding any gearbox work.
Do not fit original Rover baulk rings. Get better ones from John and any other parts
I found this very useful in explaining the issue
Edited by bogstandard, 28 August 2016 - 07:50 PM.
Posted 28 August 2016 - 08:03 PM
Posted 29 August 2016 - 07:17 AM
ok thank you for ur inputs !!!
Posted 29 August 2016 - 08:49 AM
