Which Valve Springs
3 replies to this topic
#1 idlethumbs
idlethumbs
  • 272 posts
Posted 28 August 2016 - 05:08 PM
Hi all.
I am looking at getting some head work done on my 1275 cooper spi. Opening it up to the equivalent of stage 3.
I am not looking at doing the cam as don't want the engine removed so looking at rockers instead.
Should I be going to double valve springs?
I don't really understand it all, but I guess more power and/or higher lift rockers needs stronger springs?
#2 ACDodd
ACDodd
  • Mini Docs
  • 2,832 posts
Posted 28 August 2016 - 05:10 PM
Aea 525's from minispares is all you need.
Ac
#3 Ethel
  • 26,580 posts
Posted 28 August 2016 - 05:23 PM
Stronger springs are to accelerate the valve gear fast enough to keep it in contact with the cam at higher rpm. Lighter rockers with a higher ratio help this to some degree anyway. Double springs damp each other to control bad harmonics, but quality single springs can work adequately well. Springs that are stronger than needed waste power and increase wear.
#4 idlethumbs
idlethumbs
  • 272 posts
Posted 29 August 2016 - 07:53 AM
Thankyou both. That gives me a little more understanding. I'll get the springs and rockers come payday.
