Spark Plugs
Posted 29 August 2016 - 02:21 PM
Posted 29 August 2016 - 02:42 PM
no, plugs can not effect the engine temp.
but if you engine is has a high compression and is run hard plugs with I higher heat handling ability would be good.
take it for a run and stop and check the plug colours.
Posted 29 August 2016 - 03:34 PM
i did that, seems a bit rich hasnt been on dyno yet.
on the way back( just got home ) from the pub 15 miles away from home i put in the 6 series plugs
and it seems to run slightly cooler kept at 90 didnt go to 95 as with the 7s
timing is spot on, would the 6 be dispersing the heat better
i have around 10.1 comp
