Door Hinge Studs
12 replies to this topic
#1 pete l
pete l
  • 1,376 posts
Posted 30 August 2016 - 12:42 PM
Hi all,
On my 97 MPI, the door hinge studs have seen better days and the nuts are just spinning. Can the studs be changed ? if so, is it easy to do ?
Pete.
#2 nicklouse
  • 18,696 posts
Posted 30 August 2016 - 12:48 PM
drill them out and weld new ones in.
or buy new hinges.
#3 DomCr250
DomCr250
  • 667 posts
  • Local Club: 16V mini club
Posted 30 August 2016 - 03:04 PM
or buy new hinges.
Good advice Nick, you need to take the door off, then pull the hinges off the door - new hinges are expensive (I think, but I'm a tight git) so swapping new studs on your existing ones is worth doing if the hinge itself is good.
I'd allow yourself a day if you are a leisurely worker ... it's 4 bolts to pull the door off, 5 screws to remove the hinges from the door ...however these can become stuck / rusted with age (soak them with a penetrating oil before you start for a few days) - I use a 18V drill with the correct screwdriver bit in it, an impact driver would do the same thing.  Then it's remove the old studs, weld the new ones in and spend sometime rehanging the door again.
Edited by DomCr250, 30 August 2016 - 03:04 PM.
#4 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 16,080 posts
  • Name: Neil
Posted 30 August 2016 - 04:32 PM
Its a pain to get them set correctly and welded in properly.
Now you can pick up second hand OE hinges but you may find the hinge pin is worn.
There are two types of new hinges out there, pattern and Genuine. Now personally after being bitten by pattern i would always buy genuine.
#5 minidaves
minidaves
  • 4,933 posts
  • Local Club: mine
Posted 30 August 2016 - 08:12 PM
grind the weld off and the hinge is threaded, screw new stud in and a tack weld job done
#6 pete l
pete l
  • 1,376 posts
Posted 31 August 2016 - 07:00 AM
The hinges are off the car. There is no play in the pins so I would like to keep them, new OE ones are nearly £200 for a set of 4 !!!!!!
I will have a play with one and see how it goes.
#7 Itsjustanestate
Itsjustanestate
  • 43 posts
Posted 31 August 2016 - 04:24 PM
Replaced all the studs on my hinges with 8mm A2 grade 304 stainless steel studs. Drill out the old studs. A good tip is to grind off the back of the weld flush as it is very hard to drill. Go through with a 1/8"drill and punch out what is left of the stud and drill to size. I TIG welded the new studs in with stainless weld. No more rust!
#8 Steve220
Steve220
  • 5,067 posts
  • Local Club: BMC
Posted 31 August 2016 - 04:49 PM
That's exactly how mine are getting done, nice!
#9 minidaves
minidaves
  • 4,933 posts
  • Local Club: mine
Posted 31 August 2016 - 09:05 PM
grrrr why drill them the hinge is threaded as i have said cut the weld off unscrew broken worn stud out, then fit new stud and put a nice weld on job done no drilling :)
#10 Itsjustanestate
Itsjustanestate
  • 43 posts
Posted 31 August 2016 - 09:12 PM
The weld had penetrated too deep on mine so I just snapped the studs. Much easier to grind off flat, center pop and drill. Also stainless studs will out last us all!
#11 Quincy Sparks
Quincy Sparks
  • 242 posts
  • Local Club: BHMC, MCR
Posted 20 September 2016 - 04:19 PM
Wish I'd read this last week, did a search for threads on hinges and missed this one :shy:  Pins all worn out in mine, so ordered a pattern set of hinges. Awful. Miles out when trying to line up. Genuine it is then! *sells another limb*  :ohno:
#12 sonikk4
sonikk4
  • 16,080 posts
  • Name: Neil
Posted 20 September 2016 - 07:09 PM
What was falling for us but mainly my son is he spent a lot of money on DSN billet ally hinges so after all of the gapping, welding etc I did on his doors it was all to no avail.
The lads at DSN even offered to modify the hinges to fit but as all that work had gone into gapping the door exactly with pattern hinges we politely declined. They did do a double check of the thickness of their own hinges anyway to make sure all was good and confirmed they were dimensionally correct to OE hinges.
A hard lesson learnt.
#13 Quincy Sparks
Quincy Sparks
  • 242 posts
Posted 21 September 2016 - 09:01 AM
Ah heck, sounds like a frustrating time! The guy doing my resto has repaired the doors and wants to get them hung and gapped before starting to put the new front end on - from the A Panel forward - so we're just a bit held up waiting to get some decent hinges sorted. I'm trying to stay zen about it all :) Cheers for the info!
