I am running a Specialist components 16v headed 1380 engine,
Still using the SPI relay bode, so hopefully the SPI guys can still help on this.
The battery drains after 1-2 days. Yesterday aI placed a multimeter between the negative cable and terminal on the battery and set it to amps. I could see around 1 amp on the meter.
I pulled each fuse one by one to see which one would stop the drain. It turned out to be a fuse on the SC loom. I roughly traced these wires to the relay box.
I pulled the larger terminal out and this also stopped the drain. So I guess the culprit relates to a circuit from the relay box.
How to I test which?
