What does the standard MPI have ?
2.7, as much as I loath it in my sportspack on 10's (going for a 3.2 soon), its awesome cruising just over 4k at 85..
Posted 02 September 2016 - 02:20 PM
Posted 02 September 2016 - 03:49 PM
Posted 02 September 2016 - 03:51 PM
Posted 02 September 2016 - 04:07 PM
Posted 02 September 2016 - 06:05 PM
Posted 15 October 2016 - 11:58 AM
Yes the 3.44 was fitted to the Mk.1 Cooper 'S' and it worked well.
It will give 16.5 mph per 1000 rpm in top which means about 83 mph at 5000 rpm.
Allow me to roughly sum this up... I would like to know more about mph/rpm in top gear for other FDR 2.7, 2.9, 3.1, 3.2, 3.7. Can anybody help fill out the puzzle here? Cooperman already gave two, if you know some more please share. Thanks.
2.7?
2.9?
3.1?
3.2?
3.7?
Posted 15 October 2016 - 12:10 PM
So much depends on the engine specification and the shape of the torque curve, as well as how you wish to use the car.
The mph/1000 rpm in top is just a measure of that and does not consider the fact that as the FDR gets 'taller' the gaps between the gears gets 'longer' as well. The correct gearing enables the engine to stay nicely 'on the cam' when changing up or down the gears.
With the standard gears, which are quite wide ratio, if the cam and head have been changed to give more power wand a narrower torque band, then a slightly lower FDR will help the overall performance.
That is why, for a mildly tuned road engine, say with around 70 to 80 bhp, a 3.2 or 3.44 FDR is about ideal.
Posted 15 October 2016 - 12:15 PM
have a look here
Thanks Alex, I have tried the site but seems like the site doesn't respond to me? weird.....
Posted 15 October 2016 - 12:27 PM
Cooperman, thanks for the info. My car is currently a stage 1 and it is a Cooper engine. I use it as a daily driver and drives a lotttt on motorways( top cruising speed ) I have no idea what FDR is in my car since the current owner said he was thinking of building it for track use.
From engine plate identifier of minispare, the specs are suppose to be 3.1 FDR. BUT, I assume that it is currently a 3.44 FDR, because it cruises at the same rate as what you mentioned.
"3.44 - It will give 16.5 mph per 1000 rpm in top which means about 83 mph at 5000 rpm (Credit: Cooperman)"
I am thinking of going for original 3.1 or 3.2 like you've mentioned. I do lots of high/top speed cruise. Also, thinking of porting the head and uprating the O/S valves, but still unsure about changing to Kent 266 cam kit.
Posted 15 October 2016 - 08:13 PM
With a standard gearbox I wouldn't go any higher than a 3.2:1 FDR if using a 266 cam. The 266 (or similar MG Metro cam) give excellent mid-range torque and a 3.2 will be fine and on long straight roads it will cruise well. It will stay nicely 'on the cam' through all the gears and in top will cruise well at around 4200 rpm and 70 mph, which is about ideal.
