Mini Cooper Pool Table
2 replies to this topic
#1 mab01uk
mab01uk
  • 12,537 posts
Posted 02 September 2016 - 06:21 PM
"The Mini Cooper Pool Table is made by Kent based manufacturer Chisel Pool. Home Leisure Direct are the exclusive retail partner for the UK, Europe and Worldwide sales.
It is fitted with a tournament grade slate bed pool table, to enable you to play English or American pool. The Mini Cooper pool table can be finished and customised with an almost limitless range of options.
We offer the Mini Cooper Pool table in two variants - the first, which you see pictured here, is made with a metal body. All new orders will be made using a Heritage body shell, as this provides a perfect rust free basis to work with. The patent pending space frame is then fitted and welded in place to support the whole car and pool table. You can see the two chrome feet showing under the body in the photograph below.
The other version is made with a fibreglass body. This reduces the cost considerably.
Given the weight involved, which is around 500kg, it has to be especially rigid to support a slate bed playing surface. It is also designed to be able to split into two parts to enable it to fit through normal doorways."
£24,997 in fibreglass
https://www.homeleis...glass-body.html
or £34,997 in metal
https://www.homeleis...pool-table.html
#2 minifreek1
minifreek1
  • 1,260 posts
  • Local Club: S.U.N.M.O.C
Posted 04 September 2016 - 05:43 PM
Thats a hell of a price..... Im sure Argos do a mini pool table for a lot less than that ;)
#3 Scousemouse
Scousemouse
  • 358 posts
Posted 05 September 2016 - 12:56 PM
Sooner have a REAL Mini + drive to a pool hall  :proud:
